Connecting to remote OPC Server
20 Sep 2014 09:25 #2311 by limonka
In the client computer 64-bit, in the server 32-bit. I will try it on one client 32bit.
19 Sep 2014 11:34 #2310 by support
Have you installed 32-bit or 64-bit version of OPC Core Components?
18 Sep 2014 06:59 #2308 by limonka
I have installed OPC Core Components Redistributable 105.0 version 3.00.10501
16 Sep 2014 13:43 #2294 by support
This is really weird. I still suspect something on the computer itself, maybe with the OPC Core Components. I understand that you have installed them with QuickOPC, but has that been the latest thing you installed, OPC-wise? What about the other OPC servers or clients you have there - haven't they been installed AFTERWARDS?
In your Control Panel, what does it say precisely about the OPC Core Components? In the Add/Remove Programs, what is in the "Name" column, and what is in the "Version" column?
16 Sep 2014 10:44 #2293 by limonka
Console application
16 Sep 2014 09:33 #2292 by support
What type is your project please? E.g. Windows Forms, console, Windows Service, Web service, Wep app?
15 Sep 2014 15:57 #2290 by limonka
I'm using QuickOpc 5.23. The client computer 64 bit, but I compiling the program as x86. The server computer is x86.
I can browse servers in the local computer.
After I wrote this line:
EasyDAClient.SharedParameters.Machine.BrowseFromRegistry = false;
Exception no longer occurs, returns an empty list of servers for the local computer and the remote.
I also installed QuickOpc on both computers, so OPC Core components are everywhere.
15 Sep 2014 15:19 - 15 Sep 2014 15:20 #2289 by support
this is an unusual error. I do not know the cause, but can you please provide some more bits of information?
  1. Which version and build of QuickOPC are you using?
  2. Is the client computer 32 or 64 bit system? And the server (remote) computer?
  3. Does the BrowseServers work locally, or on other remote computers?
  4. Please try disabling remote registry browsing:
Also
  • Can you please check that recent OPC Core Components are installed on both sides, from www.opcfoundation.org .
  • Note that the parameter you are setting (ClientParameters.UseCustomSecurity) only affects connections to OPC servers that are already identified. If you intent was to influence the parameters for the BrowseServers, the corresponding (same named) parameters are in the MachineParameters.
Last edit: 15 Sep 2014 15:20 by support.
15 Sep 2014 11:21 - 15 Sep 2014 11:23 #2288 by limonka
I'm trying connect to the remote server and I get the error OPC operation failure.
I tried to connect with another client, the server list is returned.
DCOM is configured.
I'm used this code:
EasyDAClient.ClientParameters.UseCustomSecurity = false;
EasyDAClient cl = new EasyDAClient();
var f = cl.BrowseServers("dms8000");
Last edit: 15 Sep 2014 11:23 by limonka.
