Examples of subscribing to data changes in OPC item
28 Aug 2014 18:14 - 28 Aug 2014 18:30 #2194 by support
There are multiple examples shipped with the product that show how OPC subscription are programmed with QuickOPC.
To open the solution with VB.NET examples, locate QuickOPC in the Start menu, and select Examples (Source Code) -> Visual Basic Examples. To open the solution with C# examples, locate QuickOPC in the Start menu, and select Examples (Source Code) -> Visual C# Examples.
There are many example projects in each solution, and the OPC subscriptions are used in several of them, e.g.:
  • Console/ConsoleDataTypes
  • Console/DocExamples (multiple examples in there; search for SubscribeItem or SubscribeMultipleItems)
  • Console/LogAsStringSql
  • Console/LogAsUnionToSql
  • Console/LogToSqlEnhanced
  • Console/SimpleLogToSql
  • Console/SubscribeFromXml
  • Console/XmlLogger
  • Windows Forms/EasyOpcNetDemo
  • Windows Forms/SubscribeToMany
See also:
Last edit: 28 Aug 2014 18:30 by support.
28 Aug 2014 18:11 #2193 by support
Sent: Thursday, August 28, 2014 7:45 PM
Subject: RE: OPC Labs Contact Form - .net Framework Issue
[...] are you able to send me a complete project I can open and run so I can grasp the concept of reading data of an onchange event. I am using Visual Studio 2010 with VB but happy to use C#.
D.
