RX observabl;es only giving one value
31 Jul 2014 10:25 - 31 Jul 2014 10:26 #2114 by support
I have reproduced the issue. It has to do with the absolute deadband again being used, same as in your previous report.
I was surprised myself to see it behave this way. It looks like that the original design used a different default when this particular overload is used, WITHOUT defaulting to the absolute deadband, which would cause both the examples - in your previous post, and this one - work as you expected.
We will revert the behavior in a future release. Thank you for reporting this.
For now, if - in this particular example - you use the code below instead, it will work:
UAMonitoredItemChangedObservable<float> dynamic = UAMonitoredItemChangedObservable.Create<float>( new UAMonitoredItemArguments( null, "opc.tcp://localhost:51210/UA/SampleServer", "nsu=http://test.org/UA/Data/;i=10853", 1000));
Last edit: 31 Jul 2014 10:26 by support.
The following user(s) said Thank You: giles
30 Jul 2014 18:57 #2111 by giles
ps I am uninstalling and reinstalling to make sure it is nothing I have done. I am running on windows 8 btw and the RX DA example works fine. I also tried it out with a node opc server and the server publishes to it and unsubscribes at the end but the observable just doesn't pick anything up except the first ....
30 Jul 2014 18:29 #2110 by giles
Your UA obbservable example (below) only produces one sample. - surely it should produce a constant stream? The opc node is definitely changing constantly on the server...
// $Header: $ // Copyright (c) CODE Consulting and Development, s.r.o., Plzen. All rights reserved. // ReSharper disable CheckNamespace // ReSharper disable PossibleNullReferenceException #region Example // Shows how to create an observable for OPC-UA monitored item changes, and subscribe to it. using OpcLabs.EasyOpc.UA.Reactive; using System; using System.Threading; namespace ReactiveDocExamples { namespace _UAMonitoredItemChangedObservable { class Subscribe { public static void Main() { Console.WriteLine("Creating observable..."); UAMonitoredItemChangedObservable<float> dynamic = UAMonitoredItemChangedObservable.Create<float>( "opc.tcp://localhost:51210/UA/SampleServer", "nsu=http://test.org/UA/Data/;i=10853", 1000); Console.WriteLine("Subscribing..."); using (dynamic.Subscribe(e => Console.WriteLine( e.Exception == null ? e.AttributeData.ToString() : e.Exception.GetBaseException().ToString()))) { Console.WriteLine("Waiting for 10 seconds..."); Thread.Sleep(10*1000); Console.WriteLine("Unsubscribing..."); } } } } } #endregion // ReSharper restore PossibleNullReferenceException // ReSharper restore CheckNamespace
and the output =
0) Return
1) "ReactiveDocExamples._DAItemChangedObservable.Subscribe.Main"
2) "ReactiveDocExamples._DAWriteItemValueObserver.OnNext.Main"
3) "ReactiveDocExamples._DAReactive.Composition.Pipeline"
4) "ReactiveDocExamples._UAMonitoredItemChangedObservable.Subscribe.Main"
5) "ReactiveDocExamples._UAReactive.Composition.Pipeline"
6) "ReactiveDocExamples._UAWriteValueObserver.OnNext.Main"
Select action to perform <0>? 4
Subscribing...
-2.361808E-31 {System.Single} @30/07/2014 18:25:56 @@30/07/2014 18:25:56; Good
Unsubscribing...
Press Enter to continue...
