SEHException
10 Jun 2014 17:40 - 10 Jun 2014 17:40 #2036 by support
Replied by support on topic SEHException
Please upgrade to version 5.23 or 5.30 first. It might be a problem that is already resolved.
Last edit: 10 Jun 2014 17:40 by support.
10 Jun 2014 16:46 #2035 by cdunlap
SEHException was created by cdunlap
I have a customer running a custom client and they experience a weird error every few months that I was hoping you would have some input on. After restarting the client, the error doesn't appear again for a few months.
They get an unhandled exception:
Description: The process was terminated due to an unhandled exception. Exception information: System.Runtime.InteropServices.SEHException at OpcLabs.EasyOpcRaw.DataAccess.CDAInnerEngine.ExecuteAlgorithm(OpcLabs.EasyOpcRaw.DataAccess.CDAInnerEngine*, CSynchronizedAlgorithm *) at OpcLabs.EasyOpcRaw.DataAccess.RawEasyDAClient.ExecuteEngineAlgorithm (CSynchronizedAlgorithm *) at OpcLabs.EasyOpcRaw.DataAccess.RawEasyDAClient.ReadMultipleItems(OpcLabs.EasyOpcRaw.DataAccess.RawDAItemArguments[]) at OpcLabs.EasyOpc.DataAccess.EasyDAClient.ReadMultipleItems(OpcLabs.EasyOpc.DataAccess.DAItemArguments[]) at OpcLabs.EasyOpc.DataAccess.EasyDAClient.ReadItem (OpcLabs.EasyOpc.ServerDescriptor, OpcLabs.EasyOpc.DataAccess.DAItemDescriptor) at OpcLabs.EasyOpc.DataAccess.EasyDAClient.ReadItem (System.String, System.String, System.String, OpcLabs.EasyOpc.VarType) at OpcLabs.EasyOpc.DataAccess.EasyDAClient.ReadItem (System.String, System.String, System.String) at DrvOPC.clDrvOPC.GetFlagValue (BDLinq.stFlag ByRef) N2N3.ClSurveille.Surveille to () at System.Threading.ThreadHelper.ThreadStart_Context (System.Object) to System.Threading.ExecutionContext.RunInternal (System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run (System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run (System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object) System.Threading.ThreadHelper.ThreadStart to ()
I see that this has something to do with an exception that is raised by unmanaged code. I am not sure what steps would be the best approach in debugging the issue - especially since it only happens once every few months! I see here that they suggest looking at this property (and I can do that) but I was wondering if you had any other suggestions on what could be causing the issue or a good place to get started.
They are using version 5.10.1316.1 of the dlls.
Thanks again for the suggestions. I really appreciate it.
Time to create page: 0.563 seconds
