Timeout Parameters
15 Apr 2014 08:10 #1838 by support
Replied by support on topic Timeout Parameters
Currently there are no operation-level timeouts in the UA part. The method call should return eventually, due to other mechanisms such as protocol-level timeout, but you cannot influence it and it can be really long.
I am aware of it, and I am keeping a record of this as a possible future enhancement.
14 Apr 2014 12:38 #1830 by cdunlap
Timeout Parameters was created by cdunlap
Is there a property analogous to EasyDAClient.InstanceParameters.Timeouts.ReadItem for the easyUAClient object in 5.3? I cannot seem to find this property anywhere for the UA client object.
I notice that when I stop my server and then try to do a read, the application hangs up and becomes unresponsive. I am guessing this is because it has a long timeout (i think default for DA client is 1 minute correct?) and is still waiting to hear back from the server. Is there a better way I should be handling this?
I know that a similar effect can be achieved through subscriptions since the MonitoredItemChanged event will occur when a connection is lost, but in certain situations I want to read instead of using a subscription.
Time to create page: 0.567 seconds
