OPC Client Software as Server Bridge
10 Apr 2014 11:05 #1821 by support
Dear Sir,
Yes, this is precisely for what QuickOPC can be used. As an OPC client, it can connect to any number of OPC servers (you can even combine e.g. OPC Data Access with OPC Unified Architecture servers), and it can transfer the data in between. You would usually call one of the “Subscribe” methods (or Read – it depends on the requirements), and then process the received values and call one of the “Write” methods. Things like error/reconnection handling are taken care of inside the component.
Let me know should you have any additional questions.
10 Apr 2014 11:04 #1820 by support
Subject: OPC Client Software as Server Bridge
Note
I´m looking for a simple Software to read Data from one OPC-Server and write it into another permanently.
Have you a programm which fits this requirements?
Thank you for your help!
Sincerely, A.
