i need how to conect to opc server using asp.net
26 Feb 2014 08:09 #1758 by support
Dear Sir/Madam,
You have indicated a contact request in your download form.
You can connect to OPC servers easily from within ASP.NET.
Here are the steps to get you started:
1. Download the product ( www.opclabs.com/downloads ).
2. Install it. You can keep the default settings.
3. From the Start menu, locate the QuickOPC product, and then select Examples (Source Code) -> Visual C# Examples or Examples (Source Code) -> Visual Basic Examples (this is for QuickOPC 5.30; for QUickOPC 5.23, the names are slightly different). It opens Visual Studio with the solution that contains examples for various technologies.
4. The ASP.NET examples are under the “Web” solution folder:
For the very first project, I recommend the project called “WebApplication1”.
There is also a document that contains list of examples available – it is available from the Start menu under Examples (Source Code) as “About Examples”, or online here: www.opclabs.com/download/file/184-examples-quickopc .
Related forum topic: www.opclabs.com/forum/general-issues/1319-how-to-develop-asp-net-opc-client-app .
Let me know if you need any further help.
26 Feb 2014 08:08 #1757 by support
[from QuickOPC Download form]
