Error "Class not registered"
19 Feb 2014 16:58 - 19 Feb 2014 17:29 #1714 by support
Hi.
Is this on 64-bit Windows?
Does your application run in 64-bit process?
Are you connecting locally, or remotely?
Last edit: 19 Feb 2014 17:29 by support. Reason: Added question about local/remote
19 Feb 2014 16:32 #1713 by Astolfi
Hi
I work with a development license for QuickOPC.NET 5.2, my application OPCclient works fine with many opc server, but recently my OPCclient is fall in some problem with a DeltaV OPC Server. In whatever way I connect with the OpcClient, I received the same error "Class not registred", but with other opclient (opctest e Matrikon explorer, and also with EasyOPCDADemo.exe (com version)) I connect with success. how i can resolve this trouble
Best Regards
Luca Astolfi
