OPC-UA Exception
15 Jan 2014 15:42 #1667 by adid@contel.co.il
Replied by adid@contel.co.il on topic OPC-UA Exception
yes this is the problem.
thank you,
Adi Damty
15 Jan 2014 15:04 #1666 by support
Replied by support on topic OPC-UA Exception
Is your "nodeId" variable always non-null?
15 Jan 2014 14:25 #1665 by adid@contel.co.il
i get this error :
Precondition failed.: NodeDescriptor != null, Stack trace : at OpcLabs.EasyOpc.UA.UANodeArguments.set_NodeDescriptor(UANodeDescriptor value)
at CI_OpcInterface.WCFService.ServiceBaseLogic.ReadMultipleTags(List`1 i_Tags, Boolean i_ThrowExceptionIfPartOfReadingFailed)
on this lines :
foreach (TagInfo taginfo in i_Tags)
nodeId = GetNodeId(taginfo.UAEndpointDescriptor, taginfo.TagName);
tagsNames.AppendFormat(@"[{0}] , ", taginfo.TagName);
uaReadArgument = new UAReadArguments();
uaReadArgument.EndpointDescriptor = taginfo.UAEndpointDescriptor;
uaReadArgument.NodeDescriptor = nodeId;
uaReadArguments.Add(uaReadArgument);
when i do uaReadArguments.Add(uaReadArgument); for some tags.
what is does this exception means?
thank you,
Adi Damty
