EasyUAClient
20 Dec 2022 08:29 #11358 by support
Replied by support on topic EasyUAClient
The ability to specify the application certificate validity period will be in QuickOPC 2023.1.
23 Jan 2014 17:40 #1684 by support
Unfortunately not - it uses some default given by the UACertificateGenerator.
23 Jan 2014 14:49 #1681 by adid@contel.co.il
when i use easyUA.Install can i also configure the ValidUntil property ?
EasyUAClient.SharedParameters.Engine.ApplicationCertificateSubject = "Contel-MES";
EasyUAClient.SharedParameters.Engine.ApplicationName = "Contel-MES";
EasyUAClient.SharedParameters.Engine.ApplicationUriString = "urn:MES_SQL_TEST:Contel_Mes:1.0.0.0:neutral:null";
EasyUAClient.SharedParameters.Engine.ProductUriString = "urn:MES_SQL_TEST:Contel_Mes:1.0.0.0:neutral:null";
EasyUAClient.Install();
thank you,
Adi Damty
