How to modify OPC connection parameters ?
21 Oct 2013 06:58 #1502 by support
This is not currently possible, you are right. It is on the list of future enhancements (but no planned delivery date yet), though.
21 Oct 2013 06:04 #1501 by krannila
OK, but then it is not that good in my application.
I'm building an application where I connect with max. 10 OPC servers in different computers.
OPC servers are from different manufacturers and therefore I'd like to tune these connections with own parameters for each OPC server type.
Regards Kari
21 Oct 2013 05:32 #1500 by support
You are right. Actually the ClientParameters is a static ("Shared" in Visual Basic) property of the EasyDAClient object, i.e. common for all its instances. The better syntax with no warning should be:
EasyDAClient.ClientParameters.ClientReconnectDelay = 30000
21 Oct 2013 04:07 #1499 by krannila
But now when I try to do this: OPCConn1.ClientParameters.ClientReconnectDelay = 30000
Visual Studio 2008 IDE warns about following:
"Access os shared member, constant member, enum member or nested type through an instance, qualifying expression will not be evaluated"
Is this still OK (code compiles with this warning) ?
Regards Kari
Public WithEvents OPCConn1 As OpcLabs.EasyOpc.DataAccess.EasyDAClient
Dim SubscriptionHandle() As Integer
OPCConn1 = New OpcLabs.EasyOpc.DataAccess.EasyDAClient()
SubscriptionHandle = OPCConn1.SubscribeItem(OPCMachineName, OPCServerClass, OPCItemName, DataType, OPC_UPDATE_RATE, Deadband, Nothing)
20 Oct 2013 14:54 #1498 by support
You cannot assign a new EasyDAClientParameters object to the EasyDAClient object, but you can modify properties of an existing one, like this:
20 Oct 2013 07:57 #1496 by krannila
I have built an OPC connection to Siemens OPC Server.
Connection works OK and I get data.
But now I'd like to modify connection parameters
- ClientReconnectDelay and so on
How to do that ?
See sample code below.
Kari
Dim ClientParameters As New OpcLabs.EasyOpc.DataAccess.EasyDAClientParameters
' How to add ClientParameter object into EasyDAClient object ?
