Problem Make StatusToColorConvert like Component
10 Sep 2013 07:33 #1419 by support
can you please select the UABinder component instance on your form, and on Events tab of its Properties, add a handler for MappingUpdateFailure event? And, inside the handler, add some code or set a breakpoint to check whether there isn't any failure reported. If there is, we will investigate. If there isn't, we will have to look somewhere else.
This event is a common way to check if there are problems with conversions, updating or getting the properties of the target (bound) objects, etc.
09 Sep 2013 14:37 #1418 by alr1976
Ok my component works like StatusToConvert component but when return value without modify i can t see anything in textbox.text
I have bind opc ua data to my textbox2.text and changed Convert in Component but doesn t show value in textbox.text
public object Convert(
// ReSharper disable AnnotationRedundanceInHierarchy
[CanBeNull] object value, [CanBeNull] object parameter, [NotNull] CultureInfo culture)
// ReSharper restore AnnotationRedundanceInHierarchy
NoContract.RequiresNotNull(culture, "culture");
// Color color = ConvertToColor(value);
return value;
