Dll error when installing software
20 Aug 2013 08:35 #1400 by support
I have found the problem, there were incorrect compiler settings for 64-bit LicenseManager which caused it to use DLL-based MFC, which was not the intent. In the typical installs, the DLL-based MFC is (being) installed anyway, so the problem won't manifest itself, but in the ".NET Production" setup type, the DLL-based MFC isn't installed (which is correct), causing the bug to show up.
This will be fixed in the upcoming build of Version 5.22.
19 Aug 2013 20:28 #1399 by rsikes
1. The OS is Windows Server 2008 R2 Standard, SP1.
2. The Customer Install | .NET Production install option was selected with the default options.
We have currently resolved this issue by copying over the missing .dlls from another machine.
19 Aug 2013 19:58 - 19 Aug 2013 19:58 #1398 by support
R., thanks for the report.
This is not related to .NET Framework version, but rather to a Visual C++ runtime.
I will investigate it - it should not be happening.
Can you please provide following details:
  • Which operating system are you installing on?
  • Have you selected "Express install" (for .NET), or any customized setup - and if so, which options were checked/unchecked?
Z.
Last edit: 19 Aug 2013 19:58 by support.
19 Aug 2013 19:11 #1397 by rsikes
I am trying to upgrade and existing system with your software to the current version. I am receiving the error shown in the attached screenshot during the installation process. I have verified that I have .NET Framework 4.0 installed on my machine, which is listed as a pre-req in the Concepts document.
I have checked the system32 directory and cannot find the .dll that the error is complaining about. Do I need to install .NET Framework 3.5? Is there a Service Pack missing that includes that file?
How do I resolve the installation error?
