Can't compile because a dll error :(
14 Jun 2013 17:58 #1338 by support
I am sorry that I have not managed to help you earlier that you did yourself.
Anyway, I am happy that it works now. The methods from OPCDataNETEngine are actually not "ours" - the object only exists for users that are migrating from other product. They should work anyway, but they used very rarely.
The following user(s) said Thank You: ricardosobrado
14 Jun 2013 10:59 #1337 by ricardosobrado
I found the problem! I was using an old method (not the correct way) to find the branches and leafs on my OPC Server. I was using the method "BrowseBranches" that is in the class OPCDataNETEngine and i should use the method "BrowseNodes" from EasyDAClient class instead
14 Jun 2013 08:55 - 14 Jun 2013 10:59 #1336 by ricardosobrado
Hi!
I'm getting a compilation problem. The error that i get is:
An unhandled exception of type 'System.Runtime.InteropServices.SEHException' occurred in x86_OpcLabs.EasyOpcClassicRaw_5.21.175.1.dll
I'm using quickOPC.NET and my project is using the .Net 4 framework. Did anyone have the same problem or have some idea how can i fix this problem?
Thanks in advance
Last edit: 14 Jun 2013 10:59 by ricardosobrado.
