How to use EasyOpcLib in SQLCLR
31 Jan 2013 07:38 #1208 by support
Oh, I see now, please drop my recent post. I realized it from your other question: You are not really using QuickOPC.NET assemblies, you are using Interop to QuickOPC-COM. That's the approach that works, but it somewhat clumsy in terms of typecasting needed, as I will explain in the answer to your other questions.
I got confused because your questions are in the QuickOPC.NET forums (yes I understand, because SQLCLR is a .NET host), but from our perspective, it is QuickOPC-COM product and component that you are using.
31 Jan 2013 07:25 #1207 by support
May I ask you whether/how you have managed to get EasyDAClient working in SQLCLR? Because, if I remember well, when we attempted that, we ran into problems with the fact there are internal assemblies that are mixed-mode (contain native code), and SQL server refused to load them.
30 Jan 2013 17:43 #1206 by rdprecure
Thank you, that is helpful. I will check for other errors as I build this component.
30 Jan 2013 16:58 #1203 by support
We do not have dedicated methods to check the validity. But there are specific error codes returned in such cases. You already know the error code for an invalid OPC server class :-). Then, there are two such errors for invalid OPC items: One is when the syntax is totally invalid, and one is when the syntax is valid but still the item does not exist. The codes for this are:
// MessageId: OPC_E_UNKNOWNITEMID
// MessageText:
// The item ID is not defined in the server address space or no longer exists in the server address space.
#define OPC_E_UNKNOWNITEMID ((HRESULT)0xC0040007L)
// MessageId: OPC_E_INVALIDITEMID
// MessageText:
// The item ID does not conform to the server's syntax.
#define OPC_E_INVALIDITEMID ((HRESULT)0xC0040008L)
Why do you want to specifically test these? (because there are other kind of errors that can also cause failures). Also note that the component does re-tries automatically (this is mainly relevant with subscriptions; if you pass in an invalid info, it may become valid, such as in case of server reconfiguration; but you do not have to put in the retrial logic, it's all handled internally by QuickOPC).
30 Jan 2013 15:52 #1202 by rdprecure
A follow up...
What is the best way to check for an OPC server or an item name that does not exist?
30 Jan 2013 15:48 #1201 by rdprecure
Holy crap! How many times did I look right at it and not see it. I guess I tried to make it too complicated. Now I'm ashamed to call myself a developer. Thank you very much.
30 Jan 2013 14:44 #1200 by support
You have a typo. It is not "OPCLabs.Kiterver.2", it should be "OPCLabs.KitServer.2".
Kind regards,
Zbynek Zahradnik
30 Jan 2013 14:21 #1199 by rdprecure
I am trying to create a user-defined-function that I can call from a SQL stored procedure. The code for the function is as follows:
Imports System
Imports System.Data
Imports System.Data.SqlClient
Imports System.Data.SqlTypes
Imports Microsoft.SqlServer.Server
Imports OpcLabs.Interop.EasyOpcLib
Partial Public Class UserDefinedFunctions
_
Public Shared Function ReadTrends() As Single
Dim opc As New EasyDAClient
Dim valu As Single
valu = opc.ReadItemValue("", "OPCLabs.Kiterver.2", "Trends.Ramp (1 s)")
Return valu
End Function
End Class
When I attempt to call the function from SQL I get the following error:
A .NET Framework error occurred during execution of user-defined routine or aggregate "ReadTrends":
System.Runtime.InteropServices.COMException: Invalid class string
at OpcLabs.Interop.EasyOpcLib.EasyDAClientClass.ReadItemValue(Object varMachineName, Object varServerClass, Object varItemId, Object varDataType, Object varAccessPath)
at OxyOPCAssembly.UserDefinedFunctions.ReadTrends()
Can anyone help me with this? Thank you.
