ReadMultipleItems Method
12 Jan 2013 09:43 #1166 by support
What you have done is a good solution, as long as the string format returned by DAVtq.ValueToString is suitable for you.
The Vtq.Value is generally an 'object', i.e. it can be of any type. The actual type depends on the OPC Server and the particular OPC item (and, on the RequestedDataType that you can specify when reading or subscribing). More information to this is e.g. in the Concepts document, "9.13 Data Types":
OPC Data Access specification is based on COM, and uses Windows VARIANT type (from COM Automation) for representing data values.
Note: Some OPC servers even use certain VARIANT types that are not officially supported by Microsoft.
Microsoft .NET Framework has a different concept, and all data is represented using an Object type. Conversions between the two are available, but not always fully possible.
In addition, not everything that can be stored in an Object can later be processed by all .NET tools and languages. Microsoft has created so-called Common Language Specification (CLS), which has certain rules and restrictions that, if followed, guarantee cross-language compatibility. Public QuickOPC.NET components (assemblies) are fully CLS compliant, and that includes the way the data types are converted to and from OPC types.
QuickOPC.NET converts data from COM to .NET according to following table:
COM type (VARIANT)
.NET type (Object)
VT_EMPTY
System.Object (null reference)
VT_NULL
System.DBNull (singleton class)
VT_I2
System.Int16
VT_I4
System.Int32
VT_R4
System.Single
VT_R8
System.Double
VT_CY
System.Decimal
VT_DATE
System.DateTime
VT_BSTR
System.String
VT_DISPATCH
System.Object (not tested)
VT_ERROR
System.Int32
VT_BOOL
System.Boolean
VT_VARIANT
converted type of the target VARIANT
VT_DECIMAL
System.Decimal
VT_I1
System.Int16
VT_UI1
System.Byte
VT_UI2
System.Int32
VT_UI4
System.Int64
VT_I8
System.Int64
VT_UI8
System.Decimal
VT_INT
System.Int32
VT_UINT
System.Int64
VT_ARRAY | vtElement
System.Array of the converted vtElement type
Types that are highlighted do not convert from COM to their “natural” .NET counterparts, because the corresponding .NET type is not CLS compliant. Instead, a “wider” type that is CLS compliant is chosen.
Types not listed in the above table at all are not supported.
Strings are internally represented in Unicode wherever possible.
BTW, it looks like that the Live Binding feature (available in version 5.20) could be a good fit for you. With Live Binding, you can set up Windows Forms controls to be "bound" to OPC data, simply by configuring it in VS Designer.
11 Jan 2013 15:42 #1149 by alissonhaubert
Good afternoon, I would like to do it this way so no need to create a condition for each text field, even found a way to do this, but have not found the ideal, because today I'm trying to leave my system as light as possible because we're having some problems with slowness. The way I found that worked was the following, you know a better method?
Label1.Text = leitura[6].Exception == null ? leitura[6].Vtq.ValueToString() : "***";
another question, what format is the return value of Vtq.Value? Double, Decimal, Float?
I thank you for understanding.
Att Alisson R. S. Haubert.
10 Jan 2013 14:13 #1147 by support
I am a bit puzzled by the question, because the answer seems obvious to me: If you want "something" be displayed in the text box in case the actual value is null, use an 'if'-then-else' statement, test the value for null, and if it is null, store the required "something" into the text box instead of converting the value to string.
If I misunderstood the question, let me know.
Kind regards,
Zbynek Zahradnik
10 Jan 2013 10:32 #1146 by alissonhaubert
Good tip, but I still can not do what I want, for example, I have a textbox where the text is vtq.value, as the quality is bad when it is null the application ends up giving error, you have some idea what can I do to pass a value in place of vtq.value if the exception is different from zero?
Below is how I'm trying to do:
DAVtqResult[] leitura = EasyDAClient.DefaultInstance.ReadMultipleItems("CoDeSys.OPC.02", new DAItemDescriptor[]
{ "PLC1:.xI_TBN_ValvBorbFechada",
"PLC1:.xI_TBN_ValvBorbAberta",
for (int i = 0; i < leitura.Length; i++)
if (leitura.Exception != null)
leitura.Vtq.Value = 000;
//and I pass the textbox value vtq.value
TextBox1.Text = leitura[1].Vtq.Value.ToString();
09 Jan 2013 18:19 #1145 by support
Each of the result objects in the result array has an Exception property. This property contains a null reference if there was no error, or it contains a non-null Exception-derived object with the error details, if there has been an error related to that position in the input (output) array. You can test the Exception property for being null (or not null), which is quite efficient (compared to throwing/catching).
If Exception is null (no error), then Vtq is non-null, so there is no need to test the Vtq then. But beware - Vtq.Value can STILL be null, if if Vtq.Quality is Bad or Uncertain.
09 Jan 2013 17:50 #1144 by alissonhaubert
another thing ...
opc if you can not find a variable I want to pass a value to it, because when he does not find a variable it crashes my application and that's not good for me, I wish that when a variable was not set to be read one default value for that position in the array
I'm trying to do it this way, but is not working, I thought he would return a null value for that position in the array, but apparently it does not.
Below is how I'm trying to do this:
using System;
using System.Web.UI;
using System.Web.UI.WebControls;
using OpcLabs;
using OpcLabs.EasyOpc;
namespace Supervisorio_V1_06_12.Paginas.M1
public partial class Comando : System.Web.UI.Page
protected void Page_Load(object sender, EventArgs e)
"PLC1:.reM_RDV_ReferenciaPotencia",
if (leitura.Vtq == null)
leitura.Vtq.Value == 000;
You know me know a more efficient way of handling errors in readmultipleitems? tried using try catch block for this, have not found a more efficient way.
I thank you for your understanding, hugs.
05 Jan 2013 18:44 #1142 by support
you can increase the time the connection is held by setting a property in HoldPeriod, e.g. for 10 minutes:
easyDAClient.HoldPeriods.TopicRead = 10*60*1000;
Zbynek Zahradnik
04 Jan 2013 19:33 #1141 by alissonhaubert
Good Afternoon
I'm using the ReadMultipleItems method, and runs every 5 minutes, but I noticed that the OPC is running for 2 minutes, how can I make amends and let the OPC running until the next execution method ReadMultipleItems. Thank you for your attention.
Alisson Houbert
Time to create page: 0.197 seconds
