GetMultiplePropertyValues
05 Dec 2012 19:55 #1137 by support
The indices (and therefore order) of elements in the result array is guaranteed to be the same as in the input array, so you can use that. This is a documented behavior (see e.g. www.opclabs.com/onlinedocs/Qui ...).
The State property is primarily meant for use in event notifications. You are right that it is not being transferred to the result objects when used with simple synchronous calls such as this one - and that was by design actually. But when looking at this design in retrospective, there is probably no reason why the State should not be transferred. Thanks for suggestion, we will improve it in future version.
05 Dec 2012 15:55 #1136 by lauraibexe
I am trying to read multiple property values via the GetMultiplePropertyValues function instead of a loop, as you say in the recomendations. I pass a value in the state variable, but in the result the state is always empty. Can you test it?
The results are in the same order than the arguments? I supose yes to know what id's is the result?
Laura
