What components to install for Runtime
29 Sep 2026 21:23 #14707 by support
If using the "full" installer: On "Product Selection" page, select "Custom Selection of Components". Then, when presented with list of components, the following should be selected:
  • Products -> QuickOPC
  • Workloads -> Production
  • Development Platforms -> COM
  • Features - Components -> COM Components
  • Features - Components -> COM Type Libraries
There isn't a choice in the installer to select the individual libraries.
For production purposes, you should actually be using the smaller "production" installer, or installing files yourself (which will then allow you to minimize the deployment further). This is all described here: www.doc-that.com/files/onlinedocs/OPCLabs-ConnectivityStudio...#Application%20Deployment.html I hope it helps. Please do not hesitate to ask more if you need more information.
29 Sep 2026 15:09 #14706 by psiebert
I'm wanting to test deploy installing the necessary runtime components before purchasing a Single Developer + Runtime license.
We will be using QuickOPC, but specifically only need the following COM Libraries for VBA integration.
OPC Labs EasyOPC-UA Components Library
OPC Labs EasyOPC-UA Primitives Library
Which components do I need to select in the installer to provide an end user access to these libraries?
