Erro connecting to UA Server
15 Sep 2023 13:34 #12150 by support
Yes, but in this case you have captured something else, not the OPC UA communication between the OPC client and the server. In your capture, all sources and destinations are 127.0.0.1.
15 Sep 2023 13:32 #12149 by escarre
Yes, the OPC-UA server is on a different device. It's not a local communication. And this king of communication is working properly in another installation. With the same code sending the user/password information. The local ip is 10.10.10.82.
15 Sep 2023 12:47 #12147 by support
Actually, even better way to do this is to set "permanently" which ports are to be decoded as OpcUa. It is described here: opcconnect.opcfoundation.org/2017/02/analyzing-opc-ua-communications-with-wireshark/ , right at the beginning.
I should say, however, that this is just about how the information is *displayed* - in order to be able to check it. It does not affect what is captured, or what you then send to us.
But, I think that in your case, you have not captured the right thing in the first place. In your original posts, the server was addressed using a specific IP address, different from 127.0.0.1. I suppose that it means that the server is on a device different from the client PC? Is so, why then have you captured the traffic between two applications on the local machine? Or maybe the numerical IP was just the address of the same box, so in fact you *do* have both the client and the server on the same computer? Please clarify.
15 Sep 2023 10:50 #12146 by escarre
Sorry, it's the first time I use this tool. and I'm trying to set the Decode As to OpcUA.
But how can configure the Decode As? What have to put in Field property? And in Value Property? No all de Field property allow me to set OpcUA Current value.
TCP port allow me to set OpcUA current value, and I set 4840 as Value. But I set this Decode As and when I open Decode As window, my configuration dissapeared.
What's doing wrong?
I
15 Sep 2023 09:37 #12144 by support
Hello.As far as I can tell, what you have captured is not the OPC UA communication. When decoded as OpcUa in Wireshark, it gives "Invalid messages" every time.You must be able to see truly decoded OpcUa messages in Wireshark yourself - do you? Otherwise it doesn't make sense to send them over.
(you need to set "Decode As" to OpcUa for affected ports or IP addresses)
Example of what I see with your captures:
Example of how it (roughly) can look like when it is correct:
    15 Sep 2023 09:19 #12142 by escarre
    Do you need more information? Anything else?
    Regards.
    15 Sep 2023 06:33 #12139 by escarre
    I attach you the WireShark trace files, connecting with Matrikon and the other one connecting with OpcLabs controls.
    14 Sep 2023 16:37 #12135 by support
    14 Sep 2023 13:58 #12133 by escarre
    I send you then image with the server configuration
    And I'm trying to use WireShark and shows me a hist : Local interfaces are unavailable because no packet capture driver is installed.
    What packet do I need to install?
    Regards.
    14 Sep 2023 12:59 #12131 by support
    Can you please collect the Wireshark trace a) with the client that does not work, and b) with the client that works, and send them to us?
    Instructions: kb.opclabs.com/Collecting_information_for_troubleshooting .
    In this particular case, the Wireshark capture will probably suffice (i.e. no need to enable the extended tracing and collect LogEntry-s, at least for the initial pass).
    Time to create page: 0.162 seconds
