excel problem with licenses
11 Apr 2022 09:38 #10800 by baldassarra
HI
the issue is solved....thx
b.r.
08 Apr 2022 10:26 #10793 by support
Replied by support on topic excel problem with licenses
Please uninstall version 2021.3, and install the current version, QuickOPC 2022.1. Your license allows version 2022.1 too.
In my test, this has resolved the problem.
07 Apr 2022 10:34 #10790 by support
this is to let you know that I have managed to reproduce the "An OPC-UA RTD Server license is not granted..." issue on one computer.
This gives me an opportunity to investigate it. Please bear with me, it will take some time. At this moment, I do not need more information form you.
I will post an update here when I have more information.
05 Apr 2022 15:06 #10785 by support
I know. I still need to do some tests to see if I can reproduce it.
Re-importing license keys wouldn't do any harm, but I also doubt that it will help.
I will let you know when I have more info.
05 Apr 2022 14:16 #10784 by baldassarra
hi
I don't recive the answer about problem.
can i try to reset the lincense by License Manager to verify if there are problems with Demo?
br
04 Apr 2022 13:10 #10776 by baldassarra
Replied by baldassarra on topic excel problem
...it is 64 bit
I use a single pc where there are activeted licenses. In this PC I have a problem
But on my PC where there is a DEMO licence I have not error...
br
04 Apr 2022 11:28 #10775 by support
I have received the License Manager screenshot.
It looks like that the licenses are installed correctly.
And, I have installed your license keys and made a test. Unfortunately I was not able to reproduce the problem. Will keep trying.
Can you tell me whether your Excel runs in 32-bit or 64-bit process? Instructions:
1. Start Task Manager (Ctrl+Shift+Esc).
2. Switch to Detail tab.
3. Enable the "Platform column"; Right-click in the table header row (where the Name, PID, Status etc. appear), choose Select columns, scroll down to find Platform, check the box, press OK.
4. Locale EXCEL.EXE row in Name column in the table. What is under the Platform column in that row please?
Additional question: Are you doing this on multiple computers and some work and some don't, or none work, or just doing it on one computer?
04 Apr 2022 06:48 #10771 by baldassarra
Hi
I have installed both licences.
At the support09 I sent the screenshot
br
02 Apr 2022 09:35 #10768 by support
have you installed both the "base" license, and the Excel Option license, on the computer where you are running this?
If so, please send me a screenshot of the License Manager dialog, with these licenses installed, to support09 (at) opclabs.com.
02 Apr 2022 08:33 #10766 by baldassarra
excel problem was created by baldassarra
hi
I have a problem when I copy a tag value from quickopc ua in excel.
In the proprety of the comments compare a message that i copy in picture.
Can you help me, please?
B.r.
