GDS
13 Aug 2021 14:28 #10109 by support
Replied by support on topic GDS
while I understand that you have is some issue with the GDS, getting error message, I do not understand what it is that you are doing.
Please follow the rules for forum posts: www.opclabs.com/forum/announcements12/2365-rules-for-forum-posts . Specifically, structure your report as 1. Steps taken, 2. Observed behavior, 3. Expected behavior.
13 Aug 2021 14:23 #10108 by rankun
GDS was created by rankun
I had install the Qiock OPC 2021.02, while registrering a UA application to the GDS in the cloud, I am able to do that, but at the same time I can also see a defualt GDS in the connection explorer. Did I need to folow some specific steps/configuration to use the local GDS on my system.
I am not able to start the GDS with the following error.
"Exception Details: TCP Connect Test Socket Error
Type: System.Net.Sockets.SocketException
ErrorCode: 10061
HResult: -2147467259 (0x80004005)
Message: No connection could be made because the target machine actively refused it
NativeErrorCode: 10061
SocketErrorCode: ConnectionRefused
Source:
TargetSite:
