Network PC Running OPC Labs
06 Jul 2020 09:30 #8644 by support
Replied by support on topic Network PC Running OPC Labs
The license key needs to be installed (it resides in registry) on any computer that runs an application built with QuickOPC, or the license key can be embedded into the application itself during build time.
This is described in User's Guide, section Application Deployment.
06 Jul 2020 09:27 #8642 by neilcooley
Hi
We have a central server running the applications and in turn Easy OPC UA. The application work when they run on the server.
When i run the same applications on the clients i get a error - see attached, this is when i run the example program.
We do have a licence so its not that.
Does each client computer not the run time licence installing or can I do it within the code (VB.Net) ?
Please advise what I need to do.
Neil
