Set Active tag
26 Feb 2020 07:08 #8248 by support
Replied by support on topic Set Active tag
Directly, there is no such possibility in QuickOPC.
If you are subscribed to an OPC item, and do not want to receive notitications, you can unsubscribe, or change the update rate -to 1 (Infinite).
25 Feb 2020 18:38 #8247 by IsmaelGalaviz1995
Hello, this may be a silly question, but I have tried se the Active/Inactive status for a tag (shown in the check box) , I have seen this feature in the Quick Client integrated, but can't see that method/property/attribute in the assembly, any idea if this is possible?
I'm working with Version 2017.1 (5.50.405.1) in Visual Studio Professional 2015
Any help or suggestion will be appreciated,
Ismael
