Too Many Subscriptions exeption
10 Mar 2023 07:44 #11612 by support
You need to report the issue on the venue that is for the library you are using. It is not here. I think it is here:
github.com/OPCFoundation/UA-.NETStandard/issues
10 Mar 2023 07:42 #11611 by sauravsharma
Hi Again,
I am using the OPC Foundation.NetStandard.OPC.UA Version 1.4.370.12 . This is I am using to fetch the tags from OPCUA server . when We are trying to see the tags in UA Expert then its showing the data in view screen. But when we are trying to fetch the tag data in Code Application then its showing the error for some of the tags
Error Name : BadTooManySubscriptions. This error I am getting with the Tags which have little similar name and only different in the taxt with last 4 characters like example:
A01.Tags.Tag1
A01.Tags.Tag2
A01.Tags.Tag3
like above example the tags are present on certain OPCUA server. While fetching only the tags with little similar name are not able to add for the Subscription. Other Tags easily adding on Subscription.
Error is coming on subscription.Create();
When I have tried to analysis it then find out that its coming on the Tags having almost similar name or big length Name of Tag.
Can you Please give me detail what will be the reason for Error BadTooManySubscriptions.?
We are connect the OPCUA server using the TCP Connection through IP address.
Please guide what will be reason for the issue.
Saurav Sharma
    08 Mar 2023 13:26 #11610 by support
    This forum is for issues related to the QuickOPC product. It does not look like you are using it.
    If you are, please post here the version you are using, and the full error message.
    08 Mar 2023 13:17 #11609 by sauravsharma
    -Hi
    I am also using OPCUa .
    I am also getting this error of BadTooManySubscriptions. This error I am getting with the Tags which have little similar name and only different in the taxt with last 4 characters like example:
    A01.Tags.Tag1
    A01.Tags.Tag2
    A01.Tags.Tag3
    Please suggest what will be cause of this problem
    One more thing the error is coming in case wher we have the subscription.DisplayName Length is greater than 50/60 characters.
    Can anyone help in this as I am not able to understand what is the problem coming in this.
    Saurav Sharma
    16 Oct 2018 19:29 #6751 by 333nt
    Thank you for your answer.
    I tried changing my IP address and this way it works.
    The server probably keeps track of the number of subscriptions made by the IP address.
    I found other open OPC UA servers on this link
    github.com/node-opcua/node-opcua/wiki/publicly-available-OPCUA-servers
    which seems to work fine.
    16 Oct 2018 19:17 #6750 by support
    this appears to be a problem on the side of the demo server itself, not QuickOPC client.
    We are already aware of the issue.
    Either the demo server is simply used by too many genuine users - in which case we would increase the limits; or, it may be under kind of DoS (denial of service) attack - in which case we would take some countermeasures. Please give us some time to resolve this.
    The demo server gets restarted regularly, so you may just retry later and be lucky so see it working.
    16 Oct 2018 18:55 #6749 by 333nt
    the problem occurs when i try to subscribe to any of the objects on the OPC UA server even using the OPC UA Demo Application and subscribing to the preset EndPoint and Node.
    OpcLabs.EasyOpc.UA.UAServiceException: OPC-UA service result - (no description available) = BadTooManySubscriptions.
    ---- SERVICE RESULT ----
    StatusCode: {BadTooManySubscriptions} = 0x80770000 (2155282432)
    The strange thing is that the program used to work just fine a week ago.
    I've already tried reinstalling quickOPC. Any advice?
