OPC UA Client for R
13 Aug 2018 08:58 #6607 by support
Replied by support on topic OPC UA Client for R
Well, our QuickOPC do is no currently designed to work from R. But, it has .NET and COM interfaces, and it should be possible to call these from R (see e.g. stackoverflow.com/questions/14862861/is-it-possible-call-a-c...-the-com-object-is-exposed-fro ).
We have little experience with R on our side, so this may get challenging. But we are willing to work with you if you want to pursue this way. Maybe we can make it work together?
10 Aug 2018 09:06 #6604 by Imad
OPC UA Client for R was created by Imad
Hello There,
In an industrial project, I have an OPC UA server running on a sb-RIO (reconfigurable inputs and outputs) that sends real-time data. I have made a dashboard using node-red since it has OPC UA nodes but now I'm trying to make my dashboards using R-Shiny. Is there any OPC UA library for R?
Thanks in advance.
