Sipass ( AE OPC ) - OPCLAB - WebAx Honeywell (DA OPC)
27 Jul 2018 07:28 #6550 by support
here is a suggested procedure:
1. If possible, download a trial version of QuickOPC ( www.opclabs.com/downloads ), play with it a little, and verify that it suits your needs.
2. Pick a product edition (Standard/Professional/Ultimate): www.opclabs.com/purchase/product-editions . As you need OPC A&E, you will need either Professional or Ultimate.
3. Pick a license type: www.opclabs.com/purchase/license-types .
4. Visit www.opclabs.com/purchase/full-price-list , select "Send me a Quotation, Proforma Invoice, or Invoice", and follow the on-screen instructions. It allows you to create the quote on-line.
27 Jul 2018 07:18 #6549 by Ducnm
Can you send me a quotes ?
27 Jul 2018 07:14 - 27 Jul 2018 07:14 #6548 by support
OPC Labs QuickOPC is a toolkit to develop OPC *clients*. So, if Sipass is an OPC A&E *server*, and Web-Ax is an OPC DA *server* (you need to verify this), then the answer positive: You can use QuickOPC to develop a "bridge" between the two.
Last edit: 27 Jul 2018 07:14 by support.
The following user(s) said Thank You: Ducnm
27 Jul 2018 06:55 #6547 by Ducnm
I have a access control system use Sipass by Siemens, a BMS system use Web-Ax 3.8 (Niagara platform) by Honeywell.
Now I want to read some information form Sipass to Web-Ax 3.8 by OPC, ex : door status, door strike, ....
But Sipass only support OPC AE, Web-Ax 3.8 only support OPC DA, so that, can i use OPCLabs to connect Sipass to Web-Ax 3.8 ?
:P :P :P :P :P :P :P
