Passing arrays and/or structs
19 Mar 2018 18:53 #6165 by support
Subscribing to arrays is no different from subscribing to scalar items. You specify parameters as usual, including the ItemID of the array item, and call the subscribe method. In the event notification, the value that you will receive will be an array.
Example (some subscribed items are scalars and some are arrays): opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...%20various%20data%20types.html
Similarly, writing to array items is the same as writing scalars. Just pass in an array as a value to the Write call.
Example: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...rite%20an%20array%20value.html
OPC "Classic" (which is what EasyDAClient is for) has no notion of "structures", therefore it cannot be directly done - no matter which server or client you use. There are workarounds, such as that the structure may be represented as multiple items in a branch - but then you lose on atomicity of operations. Anyway, it's the server who dictates how this is done - not us, on the client side.
The newer OPC Unified Architecture can work with "structures" (custom data types), and our EasyUAClient does have a support for it.
19 Mar 2018 17:52 #6164 by bobday
Can I use EasyDAClient to Subscribe and/or Write structures and/or arrays? How??
