Problem to write float..bugs?
10 Mar 2017 08:54 #5006 by support
I do not know Kepware that much. But I think it is incorrect to have a 16-bit simulated device, and then two Float tags on addresses K0000 and K0001. I think Float occupies 4 bytes, and the second tag should therefore be on K0002 or higher.
10 Mar 2017 07:38 #5005 by alr1976
Hi
I have 2 float in kepware simulation. k0001 and k0002 float (system.single). When I write k0001 change also k0002 value. for example I write 55 in k0001 it write 55 in k0001 but change also k0002 with strange number. I used k0001 and k0003 and it works. if I use k0001 and k0002 with word datatype works. so I have tested with other client(kepware client) and it works perfectly with k0001 and k0002. I use Delphi.. kepware version is 5.19
it seem that engine doesn t works with 2 float contiguos
