App Error
16 Nov 2015 07:40 #3666 by support
Replied by support on topic App Error
Have you installed all the prerequisites, such as Visual C++ redistributables? (see the documentation, under "Application Deployment").
Note that version 5.33 is superseded by version 5.35, and you are strongly advised to upgrade to 5.35 (if you have purchased any 5.3x license, you are automatically entitled to 5.35 as well). Among other changes, it is no longer necessary to install these prerequisites, when you are using version 5.35.
16 Nov 2015 06:49 #3664 by seecisud
App Error was created by seecisud
Hallo,
I have installed my application on a new machine but I give an error: app_web_OpcLabs.EasyOpcClassicRaw.x86.dll is missing.
I have a regular 5.33 professional licence and Opc server is regular licensed.
On the same machine is presente a EasyOPC 5.11 licensed of an old application.
Same situation is on my developer machine where I have no problem, and on a different machine where I have non problem. I try to reinstall QuickLabs but nothinig changed.
I try to reference the missing library on my app but nothinig changed.
