Demo example
14 Nov 2015 10:25 #3660 by support
Replied by support on topic Demo example
You are right. Thanks for pointing this out, we will update the document to reflect it.
It has worked as described in the document in an earlier version, but the ReadItemValue has since been re-implemented as an extension method, and therefore the additional "Imports" or "using" is now necessary.
The following user(s) said Thank You: pvs
14 Nov 2015 09:16 #3657 by pvs
Replied by pvs on topic Demo example
I solved the problem by adding the line
Imports OpcLabs.EasyOpc.DataAccess
at the code.
13 Nov 2015 12:54 #3656 by support
Have you also referenced the assembly EasyOpcClassicExtensions?
13 Nov 2015 12:27 #3655 by pvs
Demo example was created by pvs
I used the example from the Getting Sterted manual, but I received a error message:
textBox1.Text = easyDAClient1.ReadItemValue("", "OPCLabs.KitServer.2","Demo.Single").ToString();
ReadItemValue is not a member of the easyDAClient.
The application knows easyDAClient1, but not the method.
What did I do wrong?
