Siemens S5 support
24 Sep 2014 12:20 #2337 by support
Replied by support on topic Siemens S5 support
With a little of bit simplification, QuickOPC connects to any OPC server.
You need to obtain an OPC Server for Siemens S5 - somewhere else, we do not produce them.
From that point on, you will be able to connect to that server from QuickOPC by specifying its so-called "ProgID", and read/write/subscribe to tags by making the appropriate method calls and specifying OPC "item IDs", provided by the OPC server.
24 Sep 2014 08:21 - 24 Sep 2014 08:22 #2336 by Dirk
Siemens S5 support was created by Dirk
I'm currently working on a project involving a Palletiser which is controlled by an S5 siemens PLC. Although this is an old system it does have a Lan connector and RS232 obviously. I'm wondering if QuickOPC supports the S5 and how we should connect to it ?
Last edit: 24 Sep 2014 08:22 by Dirk.
