"Pip install opclabs_quickopc" fails in PyCharm
12 May 2025 08:44 #14177 by support
This happens when "long paths" are not enabled on Windows.
1. Exit PyCharm.
2. Enable long paths. There are multiple ways to do it (Google...). One of them - the one I used when I now reproduced your problem - was:  www.autodesk.com/support/technical/article/caas/sfdcarticles...AX-PATH-is-256-characters.html .
3. Start PyCharm and retry.
I hope this helps.
11 May 2025 23:32 #14173 by JetgirlDC
I am using PyCharm, but underlying python is 3.13 and pip is 25.0.1.  I have also tried running PIP directly from CMD window.   If it matters, the initial error message is:
  × Building wheel for opclabs-quickopc (pyproject.toml) did not run successfully.
  │ exit code: 1
  ╰─> [1317 lines of output]
      C:\Users\steve\AppData\Local\Temp\pip-build-env-x54tmbcl\overlay\Lib\site-packages\setuptools\dist.py:485: SetuptoolsDeprecationWarning: Please provide a valid glob pattern.
              Pattern 'opclabs_quickopc\\OpcLabs.QuickOpc\\*.htm' contains invalid characters.
              By 2026-Mar-20, you need to update your project and remove deprecated calls
              or your builds will no longer be supported.
              See packaging.python.org/en/latest/specifications/glob-patterns/ for details.
        for path in sorted(cls._find_pattern(pattern, enforce_match))
I have tried on multiple computers, multiple Administrator accounts, and still always the same result.  What am I doing wrong?
11 May 2025 09:36 #14172 by support
Which version of pip, and which version of Python are you running?
I could not reproduce the issue. I tested with pip 25.0.1, and Python 3.13.3.
09 May 2025 21:02 #14168 by JetgirlDC
When I type pip install opclabs_quickopc in the terminal of PyCharm, I get the message "ERROR: Failed building wheel for opclabs_quickopc".  This message is preceded by a large number of messages like this:
('C:\\Users\\steve\\AppData\\Local\\Temp\\pip-modern-metadata-1dihd12h\\opclabs_quickopc-5.82.175.dist-info\\licenses\\opclabs_quickopc\\OpcLabs.QuickOpc\\System.Security.Cryptography.ProtectedData_6.0.
0.html', 'build\\bdist.win-amd64\\wheel\\opclabs_quickopc-5.82.175.dist-info\\licenses\\opclabs_quickopc\\OpcLabs.QuickOpc\\System.Security.Cryptography.ProtectedData_6.0.0.html', '[WinError 3] The system ca
nnot find the path specified')
Any ideas?
