OPC DA item with an access path
25 Aug 2025 17:01 #14356 by support
Thank you for the suggestion. You are right, it makes sense to caution the users more prominently. We have mentioned this in the documentation ( opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...-Server%20using%20PyCharm.html , it says "You will likely get red squiggles underlining on the OpcLabs namespace in the "from ... import" statement, and on other identifiers further on in the code. Ignore it. This happens because QuickOPC is based on Python.NET, and the Python IDE cannot recognize the symbols from dynamically imported namespaces." - but it would be better to have it at more places.
22 Aug 2025 17:12 #14355 by mcerqueira
Just found your answer ate the url  OPC Labs - Can´t import modules - OPC Labs Online Forums  and it worked!!!
Thanks a lot!
Please, add this "ignore red squiggles" at the home python examples page. It can help more users with the same issue. I spent one whole day trying to solve it.
Best regards!
22 Aug 2025 16:58 #14354 by mcerqueira
Hello!
I have an issue during the import of the .NET namespaces:from OpcLabs.EasyOpc.DataAccess import *
from OpcLabs.EasyOpc.DataAccess.OperationModel import *I followed all the instructions:
1) Installed the application;
2) Installed python 3.11;
3) Installed .NET 9.0;
4) Imported the opclabs_quickopc;
5) Pythonnet is also installed.
But when I try to run the very fiisrt code example:import opclabs_quickopc
# Import .NET namespaces.
def main():
print("Hello Pycharm")
client = EasyDAClient()
value = IEasyDAClientExtension.ReadItemValue(client, '', 'OPCLabs.KitServer.2', 'Demo.Single')
print(value)
if __name__ == "__main__":
main()
I have the "Unresolved reference error" on the "OpcLabs" from argument. I searched to see if this is an error related with DLLs, but I could not describe the main reason.
Could you help me on this matter? Thanks!
04 Apr 2025 06:26 #13538 by support
(please create a new forum thread when opening a new issue; you can always hyperlink if there is some relation to other posts)
In your case, you will simply do a "read" on the variable you need. This will be one of the methods like ReadMultipleItems, ReadMultipleItemValues, ReadItem, ReadItemValue.
There are examples for it in the documentation.
The following user(s) said Thank You: wvklemov
03 Apr 2025 16:24 #13536 by wvklemov
I am subscribing to several items and would like to occasionally ask for and get the current data from those items.  How would I go about doing that?
18 Mar 2025 17:26 #13483 by support
Sorry, that's because I could not test it right now. Use this instead:
IEasyDAClientExtension.SubscribeItem(client, ServerDescriptor('', server_name), item_descriptor, DAGroupParameters(200), None)
18 Mar 2025 16:49 #13482 by wvklemov
# The QuickOPC package is needed. Install it using "pip install opclabs_quickopc".
import time
from OpcLabs.EasyOpc import *
# Item changed event handler.
def itemChanged(sender, e):
    if e.Succeeded:
        print(e.Vtq)
    else:
        print('*** Failure: ', e.ErrorMessageBrief, sep='')
# Instantiate the client object.
client.ItemChanged += itemChanged
print('Subscribing item changes...')
# IEasyDAClientExtension.SubscribeItem(client, '', 'OPCLabs.KitServer.2', 'Demo.Ramp', 200)
# Define server, ItemID, and access path
server_name = "MyServer.OPC.1" # Replace with your server's ProgID
item_id = "Time2" # Example ItemID (server-specific)
access_path = "Botch" # Example access path (server-specific)
# Create a DAItemDescriptor with ItemID and access path
item_descriptor = DAItemDescriptor(item_id)
item_descriptor.AccessPath = access_path
client.SubscribeItem(ServerDescriptor('', server_name), item_descriptor, DAGroupParameters(200), None)
print('Processing item change notifications for 30 seconds...')
time.sleep(30)
print('Unsubscribing all items...')
client.UnsubscribeAllItems()
client.ItemChanged -= itemChanged
print('Finished.')
Error being returned is:
AttributeError: 'EasyDAClient' object has no attribute 'SubscribeItem'
18 Mar 2025 16:11 - 18 Mar 2025 16:12 #13481 by support
The basic example for a subscription is here  opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...%20to%20a%20single%20item.html and it looks like this (sorry I could not test it at the moment but hopefully it is the right thing):
# The QuickOPC package is needed. Install it using "pip install opclabs_quickopc". import opclabs_quickopc import time # Import .NET namespaces. from OpcLabs.EasyOpc import * from OpcLabs.EasyOpc.DataAccess import * # Item changed event handler. def itemChanged(sender, e): if e.Succeeded: print(e.Vtq) else: print('*** Failure: ', e.ErrorMessageBrief, sep='') # Instantiate the client object. client = EasyDAClient() client.ItemChanged += itemChanged print('Subscribing item changes...') IEasyDAClientExtension.SubscribeItem(client, '', 'OPCLabs.KitServer.2', 'Demo.Ramp', 200) print('Processing item change notifications for 30 seconds...') time.sleep(30) print('Unsubscribing all items...') client.UnsubscribeAllItems() client.ItemChanged -= itemChanged print('Finished.')
In this example, replace the line with
by something like the following:
# Define server, ItemID, and access path server_name = "Matrikon.OPC.Simulation" # Replace with your server's ProgID item_id = "Random.Int4" # Example ItemID (server-specific) access_path = "SimulatedData" # Example access path (server-specific) # Create a DAItemDescriptor with ItemID and access path item_descriptor = DAItemDescriptor(item_id) item_descriptor.AccessPath = access_path client.SubscribeItem(ServerDescriptor('', 'OPCLabs.KitServer.2'), item_descriptor, DAGroupParameters(200), None)
Last edit: 18 Mar 2025 16:12 by support.
18 Mar 2025 15:51 #13480 by wvklemov
I made the changes that you suggested and I'm not sure what's next.  I looked thru the examples and I'm not sure how to subscribe.  Thanks for the assistance.
18 Mar 2025 00:08 - 18 Mar 2025 00:08 #13479 by support
I was referring to your own code that you posted here.
You have written that you get error on this line:
item_descriptor = DAItemDescriptor(item_id, access_path)
So I am suggesting to replace this line by the code I have posted, i.e.
Last edit: 18 Mar 2025 00:08 by support.
