Reading OptionSet and Extended Variables from Siemens PLC
29 Nov 2024 10:45 #13297 by support
QuickOPC has support for complex/custom data types which also works in PHP. opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...omplex%20Data%20Extension.html .
OptionSets are represented as Structures with optional Boolean fields.
I do not know what you mean by "Extended Variables". OPC UA specs do not use this term. Did you mean extended objects? They are supported.
Some examples:
- opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...ta%20-%20Read%20a%20value.html (scroll down for PHP)
- opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...0Process%20generic%20data.html
Some examples are available for PHP but not all. If you need a specific example, I can help further.
28 Nov 2024 08:21 #13292 by different
hi,
I could not find the QuickOPC PHP category, so I tried to choose the closest. The question is: Is there a way to read more complex data structures from a Siemes PLC,especially the OptionSet and Extended Variables section?
János
Time to create page: 0.154 seconds
