Can´t import modules
05 Sep 2024 12:04 #13130 by support
Replied by support on topic Can´t import modules
I wonder if you were able to proceed then?
The following user(s) said Thank You: mcerqueira
04 Sep 2024 09:26 #13110 by support
Oh, I think I see what is happening. The Python IDE is not capable of recognizing the dynamically imported namespaces (due to the fact that QuickOPC is based on Python.NET).
Just ignore the red squiggles and proceed to the next step. It should work normally.
04 Sep 2024 08:50 #13109 by htimo96
Replied by htimo96 on topic Can´t import modules
see attachment
04 Sep 2024 08:47 #13108 by support
Isn't there more information besides the read squiggles? E.g. when you click the red light bulb, or in the upper part of the editor window?
04 Sep 2024 08:22 #13107 by htimo96
yes. It is listed.
The first command (import opclabs_quickopc) is working.
but it is not possible to import "from OpcLabs.EasyOpc.UA import *"
04 Sep 2024 08:19 #13106 by htimo96
yes. It is listed.
04 Sep 2024 08:18 #13105 by htimo96
yes. It is listed.
The first command (from OpcLabs.EasyOpc.UA import *) is working.
04 Sep 2024 08:15 #13104 by support
Are you sure that you have done Step 4? ("pip install opclabs_quickopc")
Can you please verify the success of this step by issuing following command in the Terminal window:
pip list
Is there the opclabs-quickopc package listed?
04 Sep 2024 08:02 #13103 by htimo96
I want to try the QuickOPC solution in Python.
I have set up Pycharm according to the getting started. Unfortunately, I cannot import the OpcLabs.EasyOpc.UA module.
( opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...-Server%20using%20PyCharm.html )
