OPCUA: Frequent connection drops
09 Nov 2026 14:30 #14750 by support
Thank you. I have received the email. I will post here when I have a reply to this.
09 Nov 2026 13:23 #14749 by Andriy
It seems that the issue is still reproducing. This time after 4 days of operation
QuickOPC version: 5.84.416. Wireshark trace and log file sent by email
15 Oct 2026 08:57 #14730 by Andriy
I will let you know once the customer installs the patch and we confirm whether it resolves the issueBest regards
11 Oct 2026 09:50 #14727 by support
Update:
There is now one more build, QuickOPC 5.84.416, with an additional unrelated fix (memory leak in specific scenario), so if you can, just use this latest one.
The following user(s) said Thank You: Andriy
10 Oct 2026 13:26 #14726 by support
We have found "something" that might be causing the problem (unfortunately it cannot be verified with 100% certainty, because it is timing-dependent, and we do not have a local repro). Essentially, we believe that the session keep-alive algorithm in the UA-.NETStandard makes wrong calculations.
We have now implemented a work-around and multiple other measures to prevent this problem.
Please rebuild and retest with QuickOPC 5.84.415 (packages are now on nuget.org. and the installer on our Web site).
Thank your for reporting the issue and your cooperation in diagnosing it.
Best regarads
08 Oct 2026 10:01 #14725 by support
I have received the new capture & application log.
It now has the information I asked for.
And, it appears that there is no "wrong-doing" on the OPC UA server part (or the network). So we will look into what can be causing the error on our side.
I will report here when I have more information.
08 Oct 2026 08:10 #14723 by Andriy
Thank you for the prompt response. I sent you another Wireshark trace file by email
07 Oct 2026 14:27 #14722 by support
I received the application log file, thank you.
The last "keep-alive" error in the application log file is at 15:15:21.
The Wireshark capture is from 15:19:46 to 15:31:55.
So there is no keep-alive error that I can correlate.
07 Oct 2026 13:16 #14721 by support
Also,
please confirm what were the QuickOPC settings when the Wireshark capture was taken. Was it as you wrote, i.e.
sessionParameters.HoldPeriod = 60 * 1000;        // 60 seconds (default: 5 seconds)
sessionParameters.KeepAliveInterval = 60 * 1000; // 60 seconds (default: 5 seconds)
sessionParameters.SessionTimeout = 5 * 60 * 1000; // 5 minutes (default: 1 minute)
or were they at the defaults at that time?
07 Oct 2026 12:54 #14720 by support
I received the Wireshark trace, thank you. But here is what I wrote originally:
"We will need a WireShark log of the communication, and the corresponding log from the QuickOPC application, with timestamps attempting to correlate the two."
There are multiple OPC UA sessions sequence in the Wireshark trace. I do not know which at which points QuickOPC reported the keep-alive problem, and at which points it did not.
The logs from your app with QuickOPC errors are from September 29. The Wireshark trace is from September 23.
