SubscribeMultipleItems in VB(A)
09 Aug 2012 08:43 #971 by Gert-Jan
All clear. Thanks again.
I have just been playing with it a bit and got good results. I did run into another little issue to do with the use of PercentDeadband, but I will post that question on a different thread.
GJF
09 Aug 2012 08:29 #970 by support
Yes, coding for ItemChanged event is simpler.
Using MultipleItemsChanged is a bit more efficient - but not too much. The savings are in the fact that just one event is fired if there are lots of changes coming in. You still need, however, to access the details of each event by calling into the component, causing number of round-trips - so the performance savings are not big.
09 Aug 2012 08:18 #969 by Gert-Jan
That's fantastic. Thanks very much, Zbynek!
A follow-on question, if you don't mind. What is the benefit of using "_ItemChanged", instead of "_MultipleItemsChanged"? Or does it just make your sample code a bit simpler?
GJF
08 Aug 2012 16:52 #965 by support
The VB6 example project is attached.
SubscribeMultipleItems.zip
You need to reference "OPC Labs EasyOPC Type Library":
The actual code looks like this:
Dim WithEvents easyDAClient As easyDAClient
Private Sub Form_Load()
Set easyDAClient = New easyDAClient
easyDAClient.SubscribeMultipleItems _
"", _
"OPCLabs.KitServer.2", _
Array("Simulation.Random", "Trends.Ramp (1 min)", "Trends.Sine (1 min)", "Simulation.Register_I4"), _
1000
End Sub
Private Sub Form_Unload(Cancel As Integer)
easyDAClient.UnsubscribeAllItems
Set easyDAClient = Nothing
End Sub
Private Sub easyDAClient_ItemChanged(ByVal varSender As Variant, ByVal varE As Variant)
Dim eventArgs As EasyDAItemChangedEventArgs
Set eventArgs = varE
List1.AddItem eventArgs.ItemDescriptor.ItemId & ": " & eventArgs.Vtq.ToString()
End Sub
And here is a display from sample run:
I hope this helps.
08 Aug 2012 09:31 #964 by support
I will prepare it; should be today or by tomorrow.
Zbynek Zahradnik
08 Aug 2012 08:03 #963 by Gert-Jan
Hi there!
Could anyone share a bit of sample code (including declarations/references) to illustrate the use of “SubscribeMultipleItems” in VB6 or VBA? Many thanks!
GJF
