PHP Server complete properties/items array
18 Jul 2012 15:11 #928 by steveh
That's quite OK. Yes, I have implemented a recursive BrowseBranches and BrowseLeaves method that gives me precisely what I need. I should probably try harder before hollerin' next time :-)
18 Jul 2012 14:14 #927 by support
sorry that I could not answer earlier - I was just starting on this now. Anyway, I am glad you made it work (I suppose you were asking for some kind of BrowseBranches/BrowseLeaves method usage?).
Feel free to ask if you need anything else.
18 Jul 2012 14:10 #925 by steveh
Cancel the post. I have worked it out thanks.
18 Jul 2012 10:02 #924 by steveh
Greetings,I find I am using essentially identical PHP software to interrogate similar server instances, but each instance has a slightly different naming convention applied to it. Whilst it is simple enough to inspect the server structure manually and make configurations to allow for the variations, I would like to attempt having the software inspect the server structure and make decisions on the applied naming conventions without manual intervention.It seems to me a natural staring point would be to have the software build a multidimensional array containing all the properties/items readable from the server and then trawl the array to build interrogation structures accordingly.Can you point me at a PHP code example that would allow me to do this, or at least enough to get me started?TIA.
