WriteVQT
23 May 2012 11:12 #863 by support
Replied by support on topic Re: WriteVQT
In our product, "WriteVQT" is performed by EasyDAClient.WriteItem and EasyDAClient.WriteMultipleItems methods.
The "regular" writes (with just a value, no quality or timestamp) are performed by EasyDAClient.WriteItemValue and EasyDAClient.WriteMultpleItemValues methods.
Note that if you are using any of the .NET-based languages, you should rather use the QuickOPC.NET product. The methods are the same, just the parameters differ slightly.
Example (VBScript):
See IEasyDAClient.WriteItem.Main.vbs.
Rem+++
Rem This example shows how to write a value, timestamp and quality into a single item.
Option Explicit
Dim EasyDAClient: Set EasyDAClient = CreateObject("OPCLabs.EasyDAClient.5.1")
EasyDAClient.WriteItem "", "OPCLabs.KitServer.2", "Simulation.Register_I4", 12345, Now(), 192
Rem---
23 May 2012 09:46 #862 by mavhacii
WriteVQT was created by mavhacii
I need to access to OPC server 3.0, where I will be writing the "INPUT" and "OUTPUT" variables. I also will be writing the timestamp and quality for each object. Based on " www.opcfoundation.org/forum/viewtopic.php?p=12299 ", I have downloaded and tried, but could not find the "writeVQT" function. Kindly advice on how to do this. Our customer is using DNP3 OPC Server, so time is very crucial.
