missing EasyOpcLib_TLB.pas?
27 Feb 2012 18:22 #781 by support
<span style="font-family: "Arial","sans-serif"; color: black; font-size: 10pt; mso-fareast-font-family: 'Times New Roman'">Hello,
<span style="font-family: "Arial","sans-serif"; font-size: 10pt; mso-fareast-font-family: 'Times New Roman'">[....]
<span style="font-family: "Arial","sans-serif"; font-size: 10pt; mso-fareast-font-family: 'Times New Roman'">I think that the file you mention should be generated by Delphi when you Import the Type Library of QuickOPC (see the Concepts document for precise name/identification of that library). Physically, this type library is located under Bin/easyopct.dll, so you can also point directly to the file when importing, but because we are registering it with the system, it should come up in the list of available libraries (it has EasyOPC in its name).
<span style="font-family: "Arial","sans-serif"; font-size: 10pt; mso-fareast-font-family: 'Times New Roman'">Best regards,
<span style="font-family: "Arial","sans-serif"; font-size: 10pt; mso-fareast-font-family: 'Times New Roman'">Zbynek Zahradnik, OPC Labs
<span style="font-family: "Tahoma","sans-serif"; font-size: 10pt; mso-fareast-font-family: 'Times New Roman'">From:<span style="font-family: "Tahoma","sans-serif"; font-size: 10pt; mso-fareast-font-family: 'Times New Roman'"> [....]
Sent: Tue 2/21/2012 2:09 AM
Subject: missung EasyOpcLib_TLB.pas
<span style="font-family: "Times New Roman","serif"; font-size: 10pt; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">I download QuickOPC-Classic 5.12.exe and install
With Delphi i need for the example "ReadAndDisplayValue" the file EasyOpcLib_TLB.pas
This file not exist!
Maby you can halp me?
<span style="font-family: "Times New Roman","serif"; font-size: 10pt; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">[U.]
Time to create page: 0.107 seconds
