WriteMultipleItemValues in C++
28 Oct 2011 13:13 #587 by support
Now replied, and posted an updated example, See the thread mentioned in my previous answer.
26 Oct 2011 09:48 #576 by support
I will prepare this example and reply in the original thread, i.e. www.opclabs.com/Support/Online ... .
Zbynek Zahradnik
26 Oct 2011 01:55 #575 by bcook@c3i-usa.com
I need an example of how to use the WriteMultipleItemValues using C++. A prior thread showed how to use this function using fixed values. I need an example that uses variables that are holding the data to be written.
I have tried using a format such as the following:
CComSafeArray ItemDWArray(12);
ItemDWArray.SetAt(0, CComVariant(*(DWORD*)&m_sTfn1WriteCommandData.sData0));
However, this generates an exception at runtime. I need help.
