getting no callbacks for A&E
18 Oct 2011 05:16 #554 by support
The coding for A&E is quite similar to Data Access, nothing really special. However one needs to make sure that the “filter” is defined correctly, so that you do not block yourself from the events you actually want.
18 Oct 2011 05:13 #551 by support
Sent: Monday, October 17, 2011 8:03 AM
Subject: SV: Ang.: How to check OPC Server Status?
I have tried to make a AE client also but i do not get any event callbacks, but it can be some error from my side :-) I will look into it a little bit more on Wendsday. It there anything special to think about when using AE?
Best regards.
J.
