Reopening OPCUserBrowseItem dialog
14 Sep 2011 06:17 #488 by support
These objects were not meant to be used repeatedly, and currently you would not gain anything by doing so. I therefore suggest you create a new object each time.
13 Sep 2011 07:08 #486 by ads
Invoking RunMe method in UserBrowseItem class repeatedly (second, third,.. time) does not open the dialog again. It returns back immediatelly and returns pResult the same as returned during the first call. Reopening the dialog means releasing the object and creating it as new again.
Is this an undocumented property or bug?
