No method available to convert ProgID to CLSID error using PHP.
30 Aug 2024 13:12 #13090 by chris@innopak.com
Thank You.....it works!
For reference here is the correct string!
$Client2 = new COM("OpcLabs.EasyOpc.UA.EasyUAClient");
print $Client2->ReadValue("opc.tcp://192.168.223.57:4840","nsu=urn:CX-709B7F:BeckhoffAutomation:Ua:PLC1;ns=4;s=.stPlantPort.FromMWU.Realtime.ActualOrderCount");
Thanks again!
30 Aug 2024 13:06 - 30 Aug 2024 13:06 #13089 by support
Last edit: 30 Aug 2024 13:06 by support.
30 Aug 2024 12:39 #13088 by chris@innopak.com
Thanks for the quick response. But it is still not working. I get.
Failed to create COM object `EasyUAClient'
I tried.....
$Client = new COM("EasyUAClient");
$Client = new COM("EasyOpc.DataAccess.EasyUAClient");
$Client = new COM("DataAccess.EasyUAClient");
all produce COM errors.
Thank You
30 Aug 2024 12:30 #13085 by support
In your PHP code, you are trying to access the server using the EasyDAClient class, which is for OPC "Classic" servers (COM/DCOM based). However, as it can be seen from your working VBA example, and from the URL of the server (which uses "opc.tcp:"), your server us actually an OPC UA server.
So you need to change your PHP code to actually *really* match the VBA code. I.e. you need to use the EasyUAClient object, and the ReadValue method.
I hope this helps.
30 Aug 2024 12:21 #13084 by chris@innopak.com
I am in the test phase of using the COM object in VBA and PHP. I have the VBA object working no problem. I have having issues with the PHP COM not working.
VBA WORKS WITH THIS.
Dim Client As New EasyUAClient
Debug.Print Client.ReadValue("opc.tcp://192.168.223.57:4840", "nsu=urn:CX-709B7F:BeckhoffAutomation:Ua:PLC1;ns=4;s=.stPlantPort.FromMWU.Realtime.TotalScrapSheets")
PHP CODE FAILS TO OUR SERVER BUT WORKS WITH YOUR DEMO SERVER.
<?php
$Client = new COM("OpcLabs.EasyOpc.DataAccess.EasyDAClient");
// THIS CALL TO YOUR DEMO SERVER WORKS
print $Client->ReadItemValue("", "OPCLabs.KitServer", "Demo.Single");
// THIS CALL TO OUR LOCAL SERVER FAILS. IT IS THE SAME SERVER THAT THE VBA WORKS ON.
print $Client->ReadItemValue("","opc.tcp://192.168.223.57:4840","nsu=urn:CX-709B7F:BeckhoffAutomation:Ua:PLC1;ns=4;s=.stPlantPort.FromMWU.Realtime.ActualOrderCount");
FAILS “No method available to convert ProgID to CLSID”
Any insight would be appreciated.
thank you
