Alarm And Event Subscription
03 Jun 2024 09:19 #12838 by Jannie@Moore
Hi, Thank you, i think this will be enough, i have verified on my source there is no code
03 Jun 2024 08:50 #12837 by support
OPC A&E does not provide Area in the event notifications. The QualifiedSourceName, however, in AEEventData, will most likely contain an area identification in it as well, plus the source within the area. How precisely it will look (the syntax of the string) is, however, server-specific.
OPC A&E does not provide CategoryName in the event notifications. It provides a CategoryId (an integer), which is part of AEEventData. You can obtain the event category information, including how the Ids correspond to the Names, by calling EasyAEClient.QueryEventCategories. If you need the category name inside the event notification handler, you should call EasyAEClient.QueryEventCategories upfront (not inside the handler!), store the information obtained, and then use it inside the handler to convert category Id to its name.
I do not know what you mean by Code.
03 Jun 2024 06:53 - 03 Jun 2024 08:45 #12836 by Jannie@Moore
Hi there i need to be able to access Area, CategoryName and Code on the below alarm event.
public void client_Notification(object sender, EasyAENotificationEventArgs e) { try { var AE_subscription = Server.Subscriptions.FirstOrDefault(); if (AE_subscription != null) { if (e.Exception != null) { Console.WriteLine("Exception Message: {0}", e.Exception.Message); Console.WriteLine("Exception Source: {0}", e.Exception.Source); return; } if (!(e.EventData is null)) { ConditionalAlarmData alarmData = new ConditionalAlarmData { Area = null, Source = e.EventData?.QualifiedSourceName, CategoryID = e.EventData?.CategoryId, CategoryName = null, TimeStamp = e.EventData?.Time, Message = e.EventData?.Message, Severity = e.EventData?.Severity.ToString(), Condition = e.EventData?.ConditionName, SubCondition = e.EventData?.SubconditionName, Quality = e.EventData?.Quality.ToString(), Enabled = e.EventData?.Enabled.ToString(), Active = e.EventData?.Active.ToString(), Acknowledged = e.EventData?.Acknowledged.ToString(), ActiveTime = e.EventData?.ActiveTime, Code = null, AcknowledgedRequired = e.EventData?.AcknowledgeRequired.ToString() }; _fileLogger.Log($@"Testing AE " + stateItem.ConnectionString, true, "AE Client"); ; } } } catch { _fileLogger.Log($@"Error Occured while getting event data.", true, "AE Client"); } }
Last edit: 03 Jun 2024 08:45 by support.
Time to create page: 0.690 seconds
