Exception when running our release program
02 Mar 2024 20:16 #12611 by micham
The problem is solved. You may ignore this question.
02 Mar 2024 18:49 #12610 by micham
We are using version 2024.1.
When I run my program in Debug mode, it runs fine. When running the release program, I get an exception. See Below.
Any idea what is causing this exception?
Exception details:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.TypeInitializationException: The type initializer for 'UCMECFG.Module1' threw an exception. ---> System.TypeInitializationException: The type initializer for 'OpcLabs.EasyOpc.DataAccess.Forms.Browsing.DADialog' threw an exception. ---> System.IO.FileLoadException: Could not load file or assembly 'System.Diagnostics.DiagnosticSource, Version=6.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
at Microsoft.Extensions.Hosting.HostBuilder.Build()
at OpcLabs.BaseLib.Extensions.Hosting.StaticHost.CreateHost()
at System.Lazy`1.CreateValue()
at System.Lazy`1.LazyInitValue()
at System.Lazy`1.get_Value()
at OpcLabs.BaseLib.Extensions.Hosting.StaticHost.GetConfiguration()
at OpcLabs.EasyOpc.DataAccess.Forms.Browsing.DADialog..cctor()
at OpcLabs.EasyOpc.DataAccess.Forms.Browsing.DADialog..ctor()
at OpcLabs.EasyOpc.DataAccess.Forms.Browsing.DAItemDialog..ctor()
at UCMECFG.Module1..cctor()
at UCMECFG.Form1.Form1_Load(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.9181.0 built by: NET481REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
UCMECFG
Assembly Version: 2024.100.0.0
Win32 Version: 2024.100.0.0
CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/UCMECFG.EXE
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 14.8.9037.0 built by: NET481REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 4.8.9220.0 built by: NET481REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.8.9037.0 built by: NET481REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Runtime.Remoting
Win32 Version: 4.8.9214.0 built by: NET481REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.ServiceProcess
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceProcess/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.ServiceProcess.dll
OpcLabs.EasyOpcForms
Assembly Version: 5.80.75.1
Win32 Version: 5.80.75.1
CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/OpcLabs.EasyOpcForms.DLL
OpcLabs.BaseLibForms
CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/OpcLabs.BaseLibForms.DLL
OpcLabs.BaseLib
CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/OpcLabs.BaseLib.DLL
System.Xml.Linq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
Microsoft.Extensions.DependencyInjection.Abstractions
Assembly Version: 6.0.0.0
Win32 Version: 6.0.21.52210
CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.DependencyInjection.Abstractions.DLL
OpcLabs.EasyOpcClassic
CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/OpcLabs.EasyOpcClassic.DLL
OpcLabs.EasyOpcClassicCore
CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/OpcLabs.EasyOpcClassicCore.DLL
Microsoft.Extensions.Configuration.Abstractions
CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.Configuration.Abstractions.DLL
Microsoft.Extensions.Hosting.Abstractions
CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.Hosting.Abstractions.DLL
CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.Hosting.DLL
CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.DependencyInjection.DLL
Microsoft.Extensions.Logging
CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.Logging.DLL
Xceed.Zip.v6.3
Assembly Version: 6.3.17281.13580
Win32 Version: 6.3.17281.13580
CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Xceed.Zip.v6.3.DLL
OpcLabs.EasyOpcUAComponents
CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/OpcLabs.EasyOpcUAComponents.DLL
OpcLabs.EasyOpcUA
CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/OpcLabs.EasyOpcUA.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
