Can I use endpoint connection?
08 Jan 2024 18:55 #12509 by support
There are many PHP examples in the product. It depends on what you actually want to do (read, write, subscribe, ...). When QuickOPC is installed using the setup program, and "COM development" is included when making the installation, all PHP examples will be on your disk. The are also in the documentation.
To get a glimpse of the very basic ones (look under "COM", and select the "PHP" tab).:
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...Read%20a%20single%20value.html
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...rite%20a%20single%20value.html
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...de%20for%20data%20changes.html
- www.opclabs.com/products/quickopc/languages-and-tools/php
I hope this helps. Let me know if you have further questions.
08 Jan 2024 18:45 #12508 by Pala
Hì
I have seen that is possible connect OPC UA endpoint
is possible use this mode to connect by Php script?
if yes can I have documentation about this
