Xojo Client.ReadMultiple
25 Jul 2023 19:41 #11955 by support
Replied by support on topic Xojo Client.ReadMultiple
Thank you for update, I am glad that it works.
25 Jul 2023 13:19 #11952 by NorbertKollmetz
Hello now it works:
// Create EasyOPC-UA component
Dim Client As New OleObject ("OpcLabs.EasyOpc.UA.EasyUAClient")
Dim ReadArguments1 As New OleObject ("OpcLabs.EasyOpc.UA.OperationModel.UAReadArguments")
ReadArguments1.EndpointDescriptor.UrlString = "opc.tcp://opcua.demo-this.com:51210/UA/SampleServer"
ReadArguments1.NodeDescriptor.NodeId.ExpandedText = "nsu=http://test.org/UA/Data/;i=10845"
Dim ReadArguments2 As New OleObject ("OpcLabs.EasyOpc.UA.OperationModel.UAReadArguments")
ReadArguments2.EndpointDescriptor.UrlString = "opc.tcp://opcua.demo-this.com:51210/UA/SampleServer"
ReadArguments2.NodeDescriptor.NodeId.ExpandedText = "nsu=http://test.org/UA/Data/;i=10853"
Dim ReadArguments3 As New OleObject ("OpcLabs.EasyOpc.UA.OperationModel.UAReadArguments")
ReadArguments3.EndpointDescriptor.UrlString = "opc.tcp://opcua.demo-this.com:51210/UA/SampleServer"
ReadArguments3.NodeDescriptor.NodeId.ExpandedText = "nsu=http://test.org/UA/Data/;i=10855"
Dim arguments(2) As Variant
arguments(0) = ReadArguments1
arguments(1) = ReadArguments2
arguments(2) = ReadArguments3
Dim results(2) As Variant
results = Client.ReadMultiple(arguments)
For Each result As OleObject In results
var r as new OLEObject("OpcLabs.EasyOpc.UA.OperationModel.UAAttributeDataResult")
r = result
system.debuglog r.AttributeData.Value
next
25 Jul 2023 09:10 #11951 by support
Currently there is no such example, as Xojo is rare to encounter. We advise that you use the VB6 examples for start, as the differences are not big, and we have plenty of VB6 examples.
The one you are looking for is here - but maybe you are already using it: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...20nodes%20or%20attributes.html .
The bottom part of your code, from that example, can look like this (in VB6):
... ' Obtain values. By default, the Value attributes of the nodes will be read. Dim results() As Variant results = Client.ReadMultiple(arguments) ' Display results Dim i: For i = LBound(results) To UBound(results) Dim Result As UAAttributeDataResult: Set Result = results(i) If Result.Succeeded Then OutputText = OutputText & "results(" & i & ").AttributeData: " & Result.AttributeData & vbCrLf Else OutputText = OutputText & "results(" & i & ") *** Failure: " & Result.ErrorMessageBrief & vbCrLf End If Next
If you are stuck somewhere else, please describe what the problem is. I will try to "guide" you using the VB6 examples, if possible, because I do not even have Xojo installed at the moment. But if necessary, will do that, too.
25 Jul 2023 08:31 #11950 by NorbertKollmetz
Hello, is there an example code to read multiple values for Xojo.
get stuck:
ReadArguments1.EndpointDescriptor.UrlString = "opc.tcp://127.0.0.1:4840"
ReadArguments1.NodeDescriptor.NodeId.ExpandedText = "nsu=http://www.atvise.com/atServer/UA/;ns=1;s=AGENT.OBJECTS.TC_02.AV_TE"
ReadArguments2.EndpointDescriptor.UrlString = "opc.tcp://127.0.0.1:4840"
ReadArguments2.NodeDescriptor.NodeId.ExpandedText = "nsu=http://www.atvise.com/atServer/UA/;ns=1;s=AGENT.OBJECTS.TC_03.AV_TE"
ReadArguments3.EndpointDescriptor.UrlString = "opc.tcp://127.0.0.1:4840"
ReadArguments3.NodeDescriptor.NodeId.ExpandedText = "nsu=http://www.atvise.com/atServer/UA/;ns=1;s=AGENT.OBJECTS.TC_04.AV_TE"
next
