Cannot view DeltaV in Connectivity Explorer
08 Jun 2023 08:14 #11795 by support
you can use the CORFLAGS utility ( learn.microsoft.com/en-us/dotnet/framework/tools/corflags-exe-corflags-conversion-tool ) with the -32BITREQ+ option, applied to the .exe of the ConnectivityExplorer, to force it to run in 32 bits.
You can verify how ConnectivityExplorer runs using Help->About; at the bottom of the About box, there is either "32-bit process" or "64-bit process".
Re "If I cannot run 32Bit python, is there a way that QuickOPC can bridge this gap?", there currently is no other known way; but as I wrote, if we got access to actually investigate in detail the computer with DeltaV server, there *might* be a way.
07 Jun 2023 08:20 #11791 by Mattias
Hi again,
Thank you for a rapid response.
My plan was to use Connectivity Explorer to verify that QuickOPC actually works as we need it to in our tests (we are running a test lab where DeltaV is the control system).
Can I change the Connectivity explorer to 32Bit to do this evaluation?
I'll ask around if there is a DeltaV demo available.
//Mattias
07 Jun 2023 07:51 #11789 by support
There are issues with DeltaV OPC server due to how it is registered in the system. Most OPC clients are 32-bits and can connect fine. Clients developed with QuickOPC can be either 32-bits or 64-bits, depending on how the application is built/run. If the OPC client runs in a 64-bit process, there are known issues connecting to DeltaV server.
See e.g.: support.softwaretoolbox.com/app/answers/detail/a_id/3972 .
Is your intent to do the OPC client in Python? If so, try switching to 32-bit edition of Python.
If we could get our hands on a DeltaV demo installable or a VM image with it, we might be able to develop a better workaround.
07 Jun 2023 07:32 #11788 by Mattias
I have a local server (OPC.DeltaV.1) that I can view both in OPCWatchIt and with another 3:rd party program. When I try to connect to the server with Connectivity explorer i get this (CoCreateInstanceEx: Class not registered).
The Kit server works ok (also from the Python interface) but not the DeltaV one.
I am grateful for any help.
/Mattias
