trying to access a node on a PLC but fail
26 May 2023 04:02 #11770 by support
can you please uninstall your current QuickOPC, and install the current one (that is, 5.70.1202 or later) from our Web site? We have recently fixed something similar that could be causing it.
25 May 2023 17:12 #11766 by Pala
your questions and my answer
1. Which QuickOPC version&build are you using?
5.70.1053.1
2. Does this happen only with this node, or also with other nodes?
with all nodes
3. Can you read the node from the Connectivity Explorer?
yes
4. Does it happen always, or just sometimes?
always
25 May 2023 11:25 #11765 by support
I have some questions.
25 May 2023 10:52 #11764 by Pala
we are trying to access a node on a PLC but fail
in attachment the screenshot with the node and its information
we are trying to access it with this call:
$Client = new COM("OpcLabs.EasyOpc.UA.EasyUAClient");
$value = $Client->ReadValue(
'opc.tcp://192.168.0.126:4840/ServerInterfaces/[Interfaccia server_1]',
'nsu=http://interfaccia%20server_1 ;ns=4;i=498'
printf("Value: %s<br>", $value);
but we have this error:
OPC UA service result - Error establishing a connection: BadNotConnected. Error establishing a connection: BadNotConnected
